Sovol SV07 Plus
When my printer turns on, it does not load the system and stays in an intermittent loop.
Has anyone ever experienced this?
Can you help me?
yes i have the same problem with my Sovol Sv07 Plus.
Have you get some solution ?
MY SV 07 Plus doesn’t works anymore. I see an error message with unsaved Variables, after that i make a restart an the printer doesn’t restart anymore. the starting screen is always in a never ending loop. i can connect the web frontend ca set printer temps but can’t start any jobs. access to a lot of files is possible
the file from unsvaed variables is empty an change the printer.cfg to an old version change nothing
Did you already send an email to
info@sovol3d.com ?
If not, please send the above situation with videos and pictures and your order number, and they will check with the engineers asap
yes, he told me, that they give it to an engineer, but nor response from Engineer
Maybe you have to wait about a week.
They have a lot of questions to deal with.
Hello , i am having the same issue , did Sovol answered to you? is the issue resolved?
Thanks,
Alex
