I’ve problem with my Sovol SV07. At the moment I can’t do anything with it.
If I try to do something (home all, print something, extruder), the printer shows always “paused print”.
System restore, new leveling doesn’t help.
I already tried even to replace the filament. Nothing help. It shows always that “paused print”.
In the log file I didn’t see any error msg.
This thing really does something? I mean, I recently had to remove the top mounted spool holder (no room in a temporary printer enclosure ) and totally forgot that switch that hung on it’s cable somewhere. At least no filament was passed thru. Printing went fine.
What leads to the question: Is there something in the config interface to trigger a reaction on the runout switch?
yes, I use the filament runout detector and I just see that the led turned off. the LED turn on again, after I put a stick under the detector.
Thanks a lot for your help.
Is it the “bug” from any 3D from Sovol, who use runout detector? If yes, then Sovol need to fix this “bug” right?
