SV08 pauses print randomly
Have printed flawlessly for about 100 hours on my SV08. Using default software, obico slicer, web interface on mainsail.
The printer seems to just pause randomly. Sometimes, it unloads the filament (so I thought the filament sensor was bad, but it seems OK). Sometimes it just pauses. In all cases I can just hit resume print and it continues on.
The console window just says Print paused. I tried looking at the klipper log and couldn’t see any errors indicated.
Any ideas or similar experiences?
Thanks!
False positive from ubico?
I suggest you open a ticket on info@sovol3d.com
Give them your order number and your pictures
Hey Mistral - interesting thought. You wouldn’t happen to know how do disable obico (I’m assuming a typo - not familiar with ubico), would you?
Thanks!
Just a follow up. This problem turned out to be noise from the print head. A ferrite bead on this cable solved the problem and now it prints as before. Not sure what changed from the initial prints to cause the problem.
