Sovol printer leveling problems
My printer has been having problems where it seems very smushed and then it like creates build ups and fails most of the time. i’ve tried all the leveling options liek z offset and bed mesh. it only works when i manually change the z offset every print but still isn’t consistent because th next print it gets slightly worse and its a cycle
Sovol has auto zoffsetcalibration locate in several macros… i manually set my zoffset, than i find and change/comment the auto zoffset in start_print and bed_mesh_calibrate macros locate in macros.cfg..
