Sovol 4 will not auto level or feed extruders?
i bought my sovol 4 a year ago was moving so never set it up when i did it worked at 1st but then auto leveling stops and screen goes back to begging screen none of functions except the move functions work no filament load no measurements none of that works says it is but just sits there message says sometimes this takes minutes but i have left for hour still stays the same is there a way to reset interface
Usually powering off wil help to get back to the starting point in case the SV04 is stuck…
Which firmware version is installed on your SV04?
Did you follow the setup instructions that came on the SD-card of your SV04?
