Slow print speeds on Sovol SV07+
I’m hoping to get some advice on print profiles for my new Sovol SV07+.
I feel like I’m not getting the performance, and I’d love some tips on how to properly set up a profile to take advantage of the printer’s speed.
Any advice or recommended print profiles would be greatly appreciated!
Thanks in advance.
Have you tuned your processes to get EXCELLENT prints at the speed you are currently printing? Going faster is going to MAGNIFY any issues that are barely “good enough”.
I have a SV07 (not the +) and have had decent results with Christian Vick’s add ins. Package includes a ton of macros and Orca profiles.
Read the comments at Printables as there are typos in one of the macro modules that break the whole system. You’ll have to edit the file to use the macros. They work well once you get them debugged.
The faster profiles use the aux cooling fan a lot. It is LOUD so be ready when a print that has been printing for hours suddenly triggers bridge/overhang mode.
BUT I got tired of Fast prints that fail and now use only his 100mm/s profiles and then slow them to 60-75% with a global speed override. A good print at 60mm/s on the first try is faster than 3 filed tries at 150 then giving up and then printing at 75. Wastes less filament too.
