Disappointing print speed
I’m fiddling around with the zero, but I must say I find the speed underwhelming.
Whenever I slice a benchy with default PETG profiles and 10% infill for the Zero it will take roughly 45 minutes, on it’s bigger brother the sv08 it will take approximately 30 minutes.
That’s not what I expected
I can crank up the speed to 300% and it will still print fine, but the total print time is still nowhere near the speed I expected from the headlines in the ad.
Are there updated profiles anywhere or is this just a case of endless fiddling around trying to get the max speed ?
If I remember right, the pre-sliced Benchy on the USB printed at 8:45 min.
The stock profiles for the Zero have a more reasonable speed, a little faster then the A1 Mini.
If you didn’t get any files on the USB, you can find them here.
EDIT: I edited my post to post the real Benchy speed at 8:45 min.
There was no benchy on the usb, but I found a gcode version that some engineer at sovol apparently sliced with insane settings, it printed in 8 minutes but was far from perfect.
I just find it strange that the default profiles are worse speed wise than the sv08
Where did you find this profile?
I edited my post above after looking for the Benchy that came with the Zero, it was at 8:45 min.
I am also surprised that the Zero would be slower than the SV08 (although the SV08 Max is the closer comparison architecturally).
Could you post or link their 8:45 speed benchy? Then I can compare those insane settings to the stock profile, maybe split the difference between them to create a faster profile that isn’t so “far from perfect”
You’ll find it in this post:
OK, here are the differences between stock and speedBenchy. I also made an intermediate column that splits the difference.
Not sure when I’ll get around to turning this into some new profiles, but I’ll post them here if somebody doesn’t beat me to it!
Stock speedBenchy Intermediate
Benchy Time 31m11s 8m22 20m?
accel_to_decel_factor 25% 50% 37%
additional_cooling_fan_speed 75 100 87
bridge_acceleration 50% 100% 75%
bridge_flow 1.2 1.0 1.1
bridge_speed 50 200 125
brim_type auto_brim outer_only ?
brim_width 5 2 3
deretraction_speed 40 60 50
elefant_foot_compensation 0 0.1 0.05
enable_extra_bridge_layer disabled ?
enable_pressure_advance 1 0 ?
extrusion_rate_smoothing_external_perimeter_only 0 ?
fan_cooling_layer_time 80 10 45
fan_min_speed 70 100 87
filament_max_volumetric_speed 21 50 35
filter_out_gap_fill 0 8 4
fuzzy_skin_noise_type classic ?
fuzzy_skin_octaves 4 ?
fuzzy_skin_persistence 0.5 ?
fuzzy_skin_point_distance 0.3 0.8 0.55
fuzzy_skin_scale 1 ?
fuzzy_skin_thickness 0.2 0.3 0.25
gap_fill_target nowhere topbottom ?
gap_infill_speed 200 400 300
infill_direction 45 0 ?
infill_wall_overlap 15% 10% 13%
initial_layer_acceleration 1000 20000 10500
initial_layer_infill_speed 105 300 202
initial_layer_jerk 5 9 7
initial_layer_line_width 0.42 0.5 0.46
initial_layer_speed 55 300 177
initial_layer_travel_speed 60% 100% 80%
inner_wall_acceleration 12000 0 6000
inner_wall_jerk 5 9 7
inner_wall_line_width 0.4 0.5 0.45
inner_wall_speed 400 500 450
internal_bridge_angle 0 ?
internal_bridge_density 100% ?
internal_bridge_fan_speed -1 ?
internal_bridge_flow 1.2 1.0 1.1
internal_solid_infill_line_width 0.45 0.55 0.50
internal_solid_infill_speed 200 250 225
ironing_inset 0 ?
lattice_angle_1 -45 ?
lattice_angle_1 45 ?
layer_height 0.2 0.25 0.22
line_width 0.4 0.50 0.45
machine_max_jerk_e 2.5 5 3.7
machine_max_jerk_x 5 9 7
machine_max_jerk_y 5 9 7
machine_max_speed_e 50 150 100
max_travel_detour_distance 100% 0% 50%
minimum_sparse_infill_area 15% 0% 8%
nozzle_temperature 210 215 213
nozzle_temperature_initial_layer 230 255 243
nozzle_temperature_range_high 250 350 300
only_one_wall_first_layer 0 1 ?
only_one_wall_top 1 0 ?
outer_wall_acceleration 10000 0 5000
outer_wall_jerk 5 9 7
outer_wall_line_width 0.4 0.5 0.45
outer_wall_speed 350 500 425
overhang_2_4_speed 50 120 85
overhang_3_4_speed 30 80 55
overhang_4_4_speed 20 50 35
precise_outer_wall 1 0 ?
precise_z_height 1 0 ?
pressure_advance 0.032 0.020 0.026
reduce_crossing_wall 1 0 ?
retract_lift_below 150 140 145
retraction_length 0.8 0.4 0.6
retraction_minimum_travel 0 1 0.5
single_loop_draft_shield 0 ?
skirt_distance 0.8 0.5 0.65
slow_down_layer_time 5 1.2 3.1
solid_infill_direction 45 0 ?
sparse_infill_line_width 0.45 0.55 0.50
spiral_finishing_flow_ratio 0 ?
spiral_starting_flow_ratio 0 ?
supertack_plate_temp 35 ?
supertack_plate_temp_initial_layer 35 ?
support_base_pattern_spacing 3.5 2.5 3.0
support_bottom_interface_spacing 0.2 0.5 0.35
support_bottom_z_distance 0.235 0.2 0.217
support_interface_pattern grid auto ?
support_interface_spacing 0.2 0.5 0.35
support_interface_top_layers 5 2 4
support_line_width 0.45 0.50 0.47
support_object_first_layer_gap 0.2 ?
support_speed 100 300 200
support_style default snug ?
support_threshold_overlap 50% ?
support_top_z_distance 0.235 0.200 0.218
support_type tree(auto) normal(auto) ?
thick_bridges 1 0 ?
top_shell_layers 4 3 4
top_solid_infill_flow_ratio 0.9 1.0 0.95
top_surface_acceleration 5000 40000 22500
top_surface_jerk 5 9 7
top_surface_line_width 0.38 0.55 0.46
top_surface_speed 200 250 225
travel_jerk 5 12 8
travel_speed 1000 1200 1100
wall_direction auto cw ?
wall_sequence inner wall / outer wall inner-outer-inner ?
wipe 1 0 ?
z_hop 0.4 0 0.2
first_layer_temperature 230 255 243
I made some profiles according to these settings and the print speed did indeed improve.. but the quality was dramatic
So I guess the advertised print speeds were just theoretical
nevertheless still a nicely built and functioning printer for this money, a big bang for the buck
Nice! An export of your profile, and perhaps some photos of the quality issues you’re observing, would be greatly appreciated.
My impression is that the bigger brand put in the labor into making well-tuned profiles, so even 6+ months after release the Zero is still at a bit of a disadvantage.
This is entirely true. I’ve seen reports that Big B had 100 mules running 24/7 for 6 months prior to their last product release. You can spend $2M on R&D when you expect to move 500K units.
Sovol can’t when they expect to move 10K units. Sovol does minimal R&D but that is carried through to a lower price point.
Big B also LOCKS their system and does everything they can to lock you into their consumables. With a huge margin on filament they can also justify more R&D dollars. As a hobbyist I prefer to support the small guy with the EXPECTATION I’m gonna have to tweak and tune.
The filament AND printer of the speedbenchy are modified… NOT just the process profile. The speedbenchy uses a specific filament profile that has much higher maximum volumetric flow rate.
To get anything near the speedbenchy, you have to be doing a maximum of about 50 mm^3/s flow (the bottom-most setting)
Printer / Extruder 1 has 0.35 retraction and NO z-hop
filament:
After slicing, the maximum speed of any part of the 8:45 benchy is 403mm/s and the maximum flow is 50.49 mm^3/s
That’s half the fun of owning things like these, IMHO. I enjoy personalising & improving things.
The **Sovol Zero**'s speedbenchy numbers aren’t practical defaults. Benchy employs a unique filament profile with a significantly greater volumetric flow. stock hotend tops out around ~50 mm³/s, so after you achieve that, increased speeds in the slicer don’t matter.
no z-hop + brief retraction is correct, accel and flow are the true constraints. tune melt capacity first, not XY speed. speedbenchy is a demo, not what the printer does out of the box.
i wanted to finish a roll of cheap PETG and played around a bit just for shits and giggles and in the end had good looking benchy in 10:39 … no 8:xx but we’re talking PETG here and you could still go more insane … these were settings still i felt very confortable with .. but the roll was finally empty ^^
