Fast Benchy Times?
Hello all, I started making a higher speed profile using the 15 minute benchy gcode that came with the printer as a guide for the profile. I was able to re-create and print one in just over 13 minutes. It came out pretty good, not perfect by any means, but good enough as a place to start tweaking. Was wondering if anyone else has had success printing a benchy at higher speeds with this machine if so what kind of quality and time did you see?
Not looking to get into speed benchy’s, just in process of creating a higher speed profile that has good quality with it and using the benchy as the test.
EDIT: Added the link to the GitHub repo.
It would be kind of you to post this profile to help other users.
Yep, figured I would. Not quite sure what that looks like yet though. Maybe I’ll get something posted up on Github. Want to get a few more tweaks in as I’ve only printed 1 so far.
EDIT: “Pics or it didn’t happen” :grin:
Here’s the link to the repo with current settings. For the time being I’ve got it setup as simply adding a custom profile in Orca. Once I get this dialed in, I will probably replace the “Fast” profile on the Sovol repo I forked. Still a work in progress though. Hoping to tweak for better quality without losing too much time as I’d like to keep this speedy.
Updated a few settings to get a little more quality out of it. This one is roughly a 15-16 minute print time vs the previous 13-14 but think the improvement is worth it.
Before & After:
