Got my SV08 a couple of days back.
After running the bed mesh it shows that the front of the bed is over 3mm lower than the back of the bed.
The bed is not warped much, but definitely slated.
Reached out to support but after some back and forth, they are asking me to run the test file that they have.
Does any one know if the bed can be leveled manually like you can on bed-slingers?
Did you run the test file?
You can find printable TPU WASHERS on Printables. The chap also has instructions on how to goabout leveling the bed with the wash wes installed. I found that my bed is alittle high in the middle and I just might try thif fix
Hope things workout for you. All the best.
Mike
