This looks a lot like the idler gear shaft issue which I also ran into. Please have a look at the last entry in Suddenly poor print quality on two SV08's - solved with extruder idler gear - #16 by wrusman to find my solution.
murphy
6
Related topics
| Topic | Replies | Views | Activity | |
| Blocked extruder | 10 | 1316 | January 12, 2025 | |
| Sovol Zero – under-extrusion caused by worn extruder gear (Solution update - loose pin)? Need advice on replacement | 6 | 203 | March 2, 2026 | |
| Quick extruder wheel question ... does this look normal? | 7 | 306 | December 8, 2024 | |
| Suddenly poor print quality on two SV08's - solved with extruder idler gear | 29 | 3361 | December 31, 2025 | |
| From good to bad overnight | 14 | 360 | July 15, 2025 |
