Power Outage Error
Hi Folks, newish to printing (since Sept 2024), I have the Sovol SV06 and never had any power issues with the printer, day or night. Late last week, I was starting to print something out and 5/10 mins it stops and presents the “Power outage error, please restart”. So I did, try to restart it and when I start up the print again, same thing happens.
I have done multiple things to help troubleshoot, making sure everything is plugged in fine, different outlets, print that I have printed before, but get the same results.
When I do other features on the printer like Auto Home, change filament, those all seem to work just fine. I have gotten my printer to work at night and during the weekend when my wife isn’t working in the basement. But it confuses me because she’s worked in the basement before and it worked fine. The area I live in is getting to it colder weather and the furnace needs to start kicking in but was fine when AC was on in Sept.
I’m checking to see if this is an issue with my printer or with my older house. Any thoughts and ideas would help a lot thank you in advance!
Since you checked the plug, the next thing would be the SD Card. Sometimes their will be a temp file from an incomplete print or some other corrupt file. Reformat or replace the SD Card & see if the problem goes away. Also make sure the Power Supply is still set to the correct voltage (red switch).
Awesome thank you, I will check these when I get home form work!
I thought I would respond back, after some more testing and doing the reformatting, everything seems to be working again. Thanks for your help @Lion!
