Hi..
How can I order to print when the printer on difference location.? Printer at home and order to print from Office.
Thank you
Hi..
Thank you
I think Obico has that capability.
Other ways:
You can also install a VPN on your router and access your printer from outside your home as if you were at home.
thank you for your reply. I tried obico it cause machine Pause every 8mins. I will tried another that your said
