Just completed build of the printer, trying to do the z offset, bed mesh and gantry leveling, bed will heat up to 65deg it will home and then go diagonal to the same spot and not move again on all 3 tests. I have turned it off and on, returned to factory settings. I also cant get the IP address to work using the flash drive. software version is 2.4.6 from 12/23/24
Send an email to info@sovol3d.com with your order number, photos or a video of your problem.
They will contact you within a week.
Is there an underscore in your SSID? Bug in Linux won’t connect if it does. If like me you have 20+ smart home devices connected to the “bad” SSID enable Guest mode on your router and rename it.
Seeing the terminal in Mainsail or Fluidd would make diagnosing the homing issue easier.
I think the adaptive bed mesh before the print overwrite any bed mesh
