Need serious help leveling the bed
Since I got my printer 6 months ago it has been a nightmare to get the bed level. I must have spent at least 24 man hours trying to get this to work and I am requesting some help and handholding.
What I have tried:
  • Silicon spacer mod replacing the outer 4 spacers
  • Z axis alignment by fine tuning the motor screws using an empty soda can, going back and forth until level.
  • Kapton tape in the random low areas mostly around the periphery of the board
  • Octoprint mesh visualization, which after fine tuning and getting the mesh near perfect, the 1st layer was still uneven as if nothing was done at all.
At present I have gotten it to the point about 70% of the bed is level but still isnt good enough. I ignored the mesh visualization now. I have a high area about 2-3 inches wide spanning the entire Y direction on my board that is centered over the left 2 center screws, causing rough print texture. I have another random area on the lower right of the build plate that is high. I also have one small area on either side of the edge of my build plate that is low causing poor line adhesion.
Please if anyone has any knowledge I would greatly appreciate it so I dont just quit this printer all together.
Email Soval per their ‘contact us’ area on their web site for a replacement.
If you bought it through Amazon use this email: amazonus@sovol3d.com.
They will want pictures or videos that can demonstrate the issue. It is under warranty for one year.
I wouldn’t try “fixing” it.
I did all 8 screws with silicone tubing, and although it took several hours of adjust, test, adjust test, now my bed is +/- .1 side to side, which the bed map can easily make up for.
you will also want to regularly redo the soda can trick (or just print a couple standoffs so you can do both sides at the same time), because I’ve found they gradually get more out of whack over time.
If you want the 2 Z axes of your printer to always be perfectly synchronized, I advise you to install this :
I did it one year ago and since then, I have never redone the leveling.
Regards
