My Klipper screen will not boot up
My Klipper Screen starts to boot; I get the warp factor stars, then the printed robot, then the screen goes blank, and nothing.
This is repeated every time I power up the unit.
It has been working fine for weeks until this fault occurred.
The voltage supply to the screen is a good steady 24V.
What are my options please? Do I have any?
Thanks, Rob.
Does the Kilppad connect to your wifi? If the problem is in the display it is possible that the mainboard is fine.
No, it doesn’t connect to WIFI.
Is it possible to connect a PC directly to the printer to debug?
If your printer is a new one, you can open a ticket at info@sovol3d.com with your order number and pictures or videos of the issues
They will get back to you within a week.
@sovol3d
Yes a SSH session can be established via USB IF the OS loads at all. See https://torte71.github.io/InsideSovolKlipperScreen/
Thanks for listing the website. My klipper screen was in a continuous boot process so I found that I had to clear all the old uploaded files and clear the saved variables file “Cleaning up “saved_variables.cfg” and klipper rebooted correctly.
I’m curious, new to this printer S 07. Screen boots up shows splash screen then goes black…. That seems to me what happened to yours. How do I navigate with no screen and clear it out?
You can use a USB drive, copy the original update.deb on it, connect it to the Klippad and let it do a Softwareupdate. No data loss, no SSH.
update files
