There are several options:
- You could enhance the filament tension by adjusting the idler screw of each extruder.
- You could calibrate your extrusion for each extruder.
- You could unplug & skip the stock filament sensors that tend to hamper the filament flow.
- You could adjust your slicer setting “extrusion multiplier” / “flow” rate for that filament type.
