Major issue
MAJOR ISSUE
Error if ask for OrcaSlicer to print Lot’s of ERRORs please see image
ALSO reflashed Firmware
Than after Bed Mesh NOTHING but Booting for ever
Get it “almost” working then this destroys everything; printing for USB dive; have to reflash, etc
Internal error on command:“G1”
From your pic it looks like you were trying to send a file to the printer & it failed.
That is an internet or cloud issue, re-flashing wouldn’t have fixed that.
I don’t know anything about Klipper, so someone else will have to help.
No WiFi at all shown not even the default after reflashing about 5 times; first 4 times it did not fully work.
All happed after filament hook on the end jammed so it thought it was 3D printing but it wasn’t because the filament was jammed.
I have manged to 3D print one small test file off a USB drive, after all the reflashing. So that is something
I will look again tomorrow in the UK
Show IP shows no IP not even the 127.O … default.
Thank you
You can print by SD Card, so that’s good.
Try this:
I would be really surprised if such an explanation is not in the user manual.
FAILS SOVOL NOT MAINLINE KLIPPER
GOT IT working for all of 10 minutes than NO WiFi or LAN and nothing in Show IP:
A WASTE OF TIME
Factory Resets, reflash NOTHING works
EDIT: Moved to existing thread Lion
Is this the stock firmware and settings or have you modified anything on it ?
It is working now, (same method same raw code), after about 25 firmware installations using the same method.
Don’t expect it to last long working.
Very odd indeed.
Hope it lasts a long time.
After getting it working I uploaded some modified configuration files and it still works
Don’t modify too much, as it may corrupt other settings.
In my opinion all the “must change” firmware settings you see on youtube etc have minimal or maybe even an adverse effect.
The biggest change for me was mounting a regular M12 probe and fixing the extruder gear pin, after that I never needed a heat-soak or whatever and the printer just prints whatever I throw at him
SOVOL don’t use Full Klipper
YES Don’t modify too much, as it may corrupt other settings
printer.cfg (11.8 KB)
raise_z_5.cfg (1.5 KB)
raise_z_50.cfg (1.6 KB)
M300.cfg (801 Bytes)
Layers and other Sovol SV08 issues Fix that pin
Unused:- but macro may need a fix to the PAUSE
heatsoak_bed.cfg (3.4 KB)
Macro.cfg (19.7 KB)
timelapse.cfg (22.0 KB)
