this morning I found this loose part lying underneath my SV06 Plus ACE. Looks like some sort of metal spacer that would fit around an M3 screw. I wonder what it fell off of?
I’m using my ACE at the moment, I will look around after the print is finished.
I flipped my ACE over & looked around, I don’t see anything that looks like it.
I also looked around other areas of the printer & still nothing.
My only guess would be the Y Axis tension wheel or pulley.
thanks for checking.
I figured it out, it goes on the screw that holds the filament sensor in place. My filament sensor had come loose and I must have missed it when I put it back on.
That’s funny, I looked at the sensor but didn’t look behind it.
you wouldn’t see it unless you removed the sensor. It sits behind it inside the little bracket that it mounts to.
Maybe it’s different between the sv06 plus ACE and the Sv06 ACE .
