Hello. I need some help wiht this small piece of the Planetary to know where came from, which came loose and I don’t know where to put it
thank you!
Its a tube like 5mm x 4mm, metal !
thank you!
Looks like a spacer to me.
What that means ???
Can you provide a direct answer ?
I really want to fix my printer !
hi, thanks for reply… its part of the toolhead 100% sure, id also try with the cad file SV08/STEP/0JXHSV08-00000 框架打印机整装 Frame 3d printer pre-assembled.zip at main · Sovol3d/SV08 · GitHub and i didnt find it… but that Planetary Direct Drive Extruder is the old one.
im gonna keep trying !!!
looks like one of the spacer in between tool head boards
Perfect… thanks you !!!
In my version i have only 1 spacer the in the bottom… the top one is a T spacer and the extra is for the cover !
I also had a similar piece fall out when I replaced the hot end with a microswiss. It went up in the hole where the filament comes down through. So for me, the two spacers for the board and where the filament comes through where the hotend goes are the only places I have seen these.
