Hello ive got issues when i pause the printer even for a second when it starts its shifting the layer and prints in the air. I did couple calibrations but didn’t solve the issue also there is really strange noise from the bed when under calibration. Dont know if the issue is because of leveling or firmware. Also it already broke the nozzle brush i dont know if this is something usual or its due to a problem
Did you check this point :
Still the bed doing noise when is doing the calibration but will seee when printing
I’m pretty sure you forgot the foam block
I removed it and still doing like this after calibration and even factory reset
Dont know really what to do…
You’re talking about the block on the back of the printer between the bed and the rails. The one you can’t see?
Yea i took it out, then factory reset and still the nozzle is going there and scratching the bed plate, i don’t know why…
When you have done your factory reset, have you redone the automatic auto calibration?
Yes its completed, but still the bed is doing noise and the nozzle is scratching the bed as i showed on the pic
It can happen.
You should open a ticket at info@sovol3d.com with pics or videos and your order number.
They’ll contact you quickly within a week.
Will do , thank you for your time as well
Not sure if it would be any help now, but I had similar issues straight out of the box of some dramatic layer shifting after the first dozen or so layers. After my hotend fully busted through my attempts to fix and clean it, they sent me a replacement. After that my printer basically acted like the perfect little princess, no issues with Z offset or layer shifting anymore. I also got a textured PEI plate from com-grow based on a recommendation at the time but I dont know how much it affected the fix. My theory is due to the incredibly thin fragile wiring in the hotend, a lot of them get damaged during assembly and shipping and may trip up the calibration.
Hope you managed to fix it on your end ages ago! Thought I should mention my own situation just incase anyone comes looking later on.
