Inconsistent first layer across bed (right side see-through) + bed mesh looks “off” even after heat soak
Hey everyone, looking for advice from other SV08 Max owners.
I’ve had my SV08 Max for a while, and I keep running into inconsistent first layer issues specifically when printing parts that use most of the bed area.
Problem
I didn’t get a chance to grab photos of the failed first layer, but the behavior is consistent:
  • One part/area of the bed has excellent first-layer “squish” (fully opaque lines, cannot see the bed through it).
  • On the right side of the bed, the first layer becomes see-through and I can clearly see the bed between lines / gaps.
This makes me think it’s a bed leveling / gantry leveling / mesh issue rather than slicer settings.
What I’m printing with
  • Filament: SUNLU PETG HiSpeed (Black)
  • Bed temp: 75C
  • Nozzle: (see attached settings)
  • Slicer & profile: (see screenshots)
Attached screenshots:
  1. Bed mesh heatmap / visualization (after leveling)
What I’ve tried
To remove thermal drift as a variable, I did a long heat soak:
  • Bed at 75C + nozzle at 150C for ~30 minutes
    Then ran:
  • QGL
  • BED_MESH_LEVEL
Even after that, my mesh heatmap still looks very “off” / uneven, and it matches what I’m seeing in the first layer (good in one area, too high or too low on the right).
Z-offset / filament gcode
To make sure this isn’t a Z-offset inconsistency between starts, I have this in filament gcode:
; Filament gcode
SET_GCODE_OFFSET Z=-0.07 MOVE=0
What’s weird is I can dial in a Z-offset that looks perfect on one side, but it will still be under-squished and gappy on the right side.
Questions
  1. What are the most common causes of a right-side first layer under-squish on the SV08 Max even after heat soak + QGL + mesh?
  2. Does this sound more like:
    • Gantry not actually leveling correctly (QGL issue / mechanical)
    • Bed mounting / bed warp / bed tension
    • Probe inconsistency / probe mount looseness
    • X-axis twist / loose wheels / belt tension / frame square
  3. Anything specific I should check or run (commands / tests) to isolate whether it’s probe accuracy vs mechanical vs mesh application?
If there are any recommended diagnostic prints or commands, I can run them and report back.
I’d add eddy edge effect to your list. Try adjusting your mesh area to end 10-15mm further from the edge.
I didn’t even know you could do that. Is that a parameter you can adjust in the console when doing a “bed_mesh_level”?
See the [bed_mesh] section of printer.cfg
[bed_mesh]
speed: 400
horizontal_move_z: 1.5
algorithm: bicubic
mesh_min: 13,15
mesh_max: 476,490
probe_count: 60,60
fade_start: 0
fade_end: 10
scan_overshoot: 4
The parameters mesh_min and mesh_max are X,Y coordinates for the rectangle that gets measures.
As far as I can tell Sovol uses stock Klipper [bed_mesh] settings.
I changed the x, y to 486, 490 and I got these errors when running bed_mesh_calibrate.
!! Move out of range: 505.390 15.750 1.500 [0.000]
You need to decrease the size of the mesh. Try
Be sure you are in the [bed_mesh] section.
Maybe just me, but I had similar experiences. And then I had bed heating issues so I took the heater out and inspected it. all of the screws holding the heating element to the bed plate magnet were slightly loose. After warming the plate and re-torquing all of the fasteners from the center out, I was able to eliminate the bed heating issues and the un-even bed mesh. May be worth a look on your unit.
My bed mesh looks EXACTLY like your photo and I have a mesh range of 0.5.
Did you find the solution for this problem? Someone told me the extruder might be the problem but I only printed petg and its under 500h
@mooseprinter did you ever find a solution for this? i am going through the exact same problem now.
