The x-axis bracket, the one that the extruder sits on, is not level. I need to do a procedure like in this video for the SV01 and can’t figure out how to disable steppers in the interface of my SV01 Pro. Any pointers to a document or video for how I level the x-axis bracket on the SV01 Pro? Or minimally how do I disable the steppers so that I can asynchronously adjust that bracket on one side? Thanks.
I don’t own an SV01, but in my other Marlin printers it’s under Prepare (scroll to the end of the list).
Thanks for the reply. The SV01 Pro has a (newer?) touch interface. But your reply did prompt me to go online again just to find out what the touch interface was called. And in the first review I watched, he mentioned disabling the stepper on a screen so that solves this issue and I now know how to choose disable stepper in this interface. I still need to figure out what I need to loosen to be able to independently adjust one of the z-axis but this is progress!
Edit: obviously I don’t know what I’m doing as after disabling the steppers, the other z-screw still spins when I spin one side. So I’m still not yet able to adjust the z-axis independently yet but I’ll keep working at it.
That’s the same screen that’s on the SV06 Plus.
After you get it printing again, print a set of blocks to measure with.
I use these of both my SV06’s & Ender 3 Pro…I just set them at each end of the bed & not the frame…so the nozzle doesn’t touch the bed.
Got it. I the x-bracket level and the bed is level now. Thanks a bunch.
