SV04 Setup - Adjust X Axis
I am assembling an SV04 for the first time and noticed something while adjusting the X axis…
After disabling the stepper motors and manually moving the Z-screw to place the spacer pieces to level the X axis, when I let go of the left Z-screw, it turns/falls about 1/4 turn.
Is this normal?
Since this does not happen with the right Z-screw, will this cause issues keeping a consistent bed level?
Bill
Hi Bill,
it should behave equally on both Z-axes in case your SV04 has been adjusted horizontally before. You may want to check the gantry geometry & the Z-axis bearing rollers of your SV04 as described here.
Bjoern
Thanks for the suggestion…I will double check the gantry geometry and see what I find.
Bill
