Cause I’m curious, could someone tell me how to configure Orcaslicer to use fluidd instead of mainsail?
Regards
Regards
Simply edit the IP address in the connection screen to end in :81
Mine is
10.0.0.213:81
Note the number after the colin is the “port”. The default HTTP port is 80. Whichever interface gets installed first gets assigned to 80 unless you override the default. Fluidd usually gets installed second and defaults to 81.
It doesn’t work, I’ve tried before.
I’m used with networks.
I’ve seen in literature that the port could be 4408 or 81 or several others but none work.
I think that a service must be installed but not sure.
It is possible Fluidd is not installed on your host.
SSH in and launch Kiauh and it will show what is installed and give you the option to install if you want. If Fluidd is already installed the easiest way to move it to another port is uninstall and reinstall.
Kiauh exists, but when I run kiauh.sh, it asks me to update.
I’m not sure that’s a good idea.
I’ve had no issues updating Kiauh. Even if the update does beak Kiauh your printer should boot and run as Kialh doesn’t load at boot.
Well, my Klipper is broken.
I can no longer connect to Moonraker, and the Klipper connection is dead.
Do you have any ideas on how to restore the system, or should I send an SOS to Sovol?
By the way, a factory reset is not helpful.
Which printer?
Can you still get in with SSH?
This is the SV06 ACE.
