Hello everyone,
Today I installed the latest Linux OS updates via SSH and after a restart, the display on my Sovol SV07 remained completely dark.
Even the green and blue led on top are just constantly in the same speed blinking.
And after 20-30 minutes nothing had changed.
I have bricked my embedded Linux OS…
I have found an image on the Sovol Firmware page:
But inside is only an IMG file and a balenaEtcher.exe and no instructions.
So my question:
How to restore the factory OS image for the embedded Linux?
Thank you all for your upcoming help
This was the output of the console:
mks@mkspi:~$ sudo apt upgrade linux-dtb-edge-rockchip64 linux-image-edge-rockchip64
Reading package lists... Done
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
The following held packages will be changed:
The following packages will be upgraded:
2 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 53.4 MB of archives.
After this operation, 1,288 kB disk space will be freed.
Do you want to continue? [Y/n] y
Get:1 http://armbian.hosthatch.com/apt buster/main arm64 linux-dtb-edge-rockchip64 arm64 23.02.2 [305 kB]
Get:2 http://mirrors.xtom.de/armbian buster/main arm64 linux-image-edge-rockchip64 arm64 23.02.2 [53.1 MB]
Fetched 53.4 MB in 18s (2,986 kB/s)
(Reading database ... 83634 files and directories currently installed.)
Preparing to unpack .../linux-dtb-edge-rockchip64_23.02.2_arm64.deb ...
Unpacking linux-dtb-edge-rockchip64 (23.02.2) over (22.05.0-trunk) ...
Preparing to unpack .../linux-image-edge-rockchip64_23.02.2_arm64.deb ...
Unpacking linux-image-edge-rockchip64 (23.02.2) over (22.05.0-trunk) ...
dpkg: warning: unable to delete old directory '/lib/modules/5.16.20-rockchip64/kernel/drivers/net/wireless': Directory not empty
dpkg: warning: unable to delete old directory '/lib/modules/5.16.20-rockchip64/kernel/drivers/net': Directory not empty
dpkg: warning: unable to delete old directory '/lib/modules/5.16.20-rockchip64/kernel/drivers': Directory not empty
dpkg: warning: unable to delete old directory '/lib/modules/5.16.20-rockchip64/kernel': Directory not empty
dpkg: warning: unable to delete old directory '/lib/modules/5.16.20-rockchip64': Directory not empty
Setting up linux-dtb-edge-rockchip64 (23.02.2) ...
Setting up linux-image-edge-rockchip64 (23.02.2) ...
update-initramfs: Generating /boot/initrd.img-6.1.11-rockchip64
update-initramfs: Converting to u-boot format
Free space after deleting the package linux-image-edge-rockchip64 in /boot: 160M
