Are there any grease ports for Sovol SV08 to lubricate the rails? Or any maintenance guides to maintain optimal performance.
I use grease sewing machine grease to lubricate these axes
Thank you. Which axes are you referring to? A picture would be great if possible.
I’m talking about the lead screws, the rods (Z-axis), and the horizontal bars (X and Y axes).
Actually, all the axes.
Be careful with the bearings: don’t lubricate them, because they’re usually self-lubricating.
Apply grease to screws and oil to rods and rails
Note: the linear rail sliders have a “wiper seal” intended to keep grease in and dust and other contaminates OUT of the actual bearings. Those same wipers also wipe grease or oil off and essentially make it impossible to effectively lubricate the sliders.
Translating Sovol’s part drawing SOVOL-ZERO/PDF/滑轨/MGN9H1R256Z0 直线滑轨-X.pdf at main · Sovol3d/SOVOL-ZERO · GitHub finds that they specify a HIWIN MGN9H1R256Z0 for the X axis (others have different rail lengths but the same slider).
The HIWIN MGH9 series has no provision to add lubrication. https://hiwin.com/wp-content/uploads/2026/08/HIWIN-Linear-Guideway-Catalog-1.pdf
Greasing the rails has no downside, as long as you clean off the old and apply sparingly. The improvement in slider life will most likely be trivial. NOTE: The flat “top” of the rail never touches the slider (other than the seal). Only the side groves need lube.
Do I need to disassembly the railings for this? Are there any recommended videos that I can follow? Searched Youtube but nothing much for the SV08 context.
There is NO maintenance procedure from Sovol or HIWIN.
Reassembly of these if you remove the endcaps or take the sliders off the rails is extremely hard. I’d strongly advise you to consider them “permanently lubricated” (like the wheel bearings on modern cars) and run them till they wobble or growl then replace them.
Noted. Thank you. I am just getting some very visible layer lines that I can’t seem to address with calibration.
It’s likely that lubrication has nothing to do with it
