SV08 Max Lubrication and Belt Tightening
Does anyone have any videos showing how to apply grease to the linear rails? Or step by step photos?
The SV08 Max came with two greases (one big tube of clear metal grease, one small packet of white grease), but I can’t figure out which one to use or how to put these on the rails without disassembling it. If it does need to be taken apart, I need photos or videos to be clear how.
Likewise, does anyone have any videos showing when or how to adjust belt tension?
These maintenance resources would be very very helpful for new users! Thank you,
On the belt tension, I´ve received a video from customer support (I cannot uplaod as I´m new user). The process is like the Sovol SV08. The gantry should be 150mm from the front (so not on the center) and the belt should vibrate at 110hz up to 140hz (depending on the quality that I want…). This is as much as I could get. What it matters the most is tha both belts vibrate at same frequency.
