Gaps in first layer.
Think it must be mechanical
Hit end?
I don’t own an SV08…but gaps usually mean the Z-Offset is off.
https://wiki.sovol3d.com/en/How-to-Enhance-SV08-First-Layer-Printing
I use a Heat soak for 30 minutes as recommended, thanks
Hotend temp, filament type, enclosed…??
PLA, 220 C nozzle, 65 C heat bed which is soaked for 30 minute.
Calibration Z routine used, bed mesh used. Enclosed
Probably too hot (that is just a guest but 220 for PLA + enclosed, that is a lot). Your print look like very “gummy” (like TPU print). For PLA with SV08 i use 200° for the hotend and 60 for the bed (without enclosure and in my bassement : external temp is around 15°c). May you try a temp tower ? (with doors opened)
PS: oh, and, another way, did you check all screws are well tied ? I asking because if your nozzle moving, that may give also something like that (i already had that because of vibrations).
You have to leave the door & top open for PLA. Also no need to heat soak.
Your going to end up clogging up the nozzle.
Try printing at 210* for PLA & 215* For PLA+ & Silk filaments.
What slicer are you using and what are the settings that you have in the slicer?
I am asking this because I had to update Orca a few weeks ago and some settings were “discarded” I guess. So I detected that the first layer infill needed some tweaks. It was in 90mm/s and I set it to 106mm/s
As stated here
However, If I don’t preheat the bed for long time, this does not always work.
My printer is without the enclosure.
Like I said in another post this does not look good at all.
The complete print seems to suffer from under extrusion and delamination.
I think you should check the complete filament path (anything from filament spool to hot-end) for blocking, misalignment or malfunction before trying to fix first layer issues
- edit -
I watched you video and see you also suffered from the extruder pin misalignment, I hope that fixed it
