Filament color match for SV08?
Are there any recommendations for a brand/color match for the SV08’s gray pieces? Ideally to match the Sovol enclosure. I prefer ABS because I’ll be using the printer at high temps. Thanks!
For high temperature, you can also use ASA wich is much more easier to print than ABS.
Been a while, but I’m looking to design a Top Hat for the SV08 Max enclosure. Did you ever choose something that worked?
I didn’t find a real match so I just went with a gray and used PETG since I couldn’t use the printer for ABS/ASA until I had it fully enclosed. I haven’t had any issues with the heat and PETG. Eventually I will change the color but that’s not even on my list of things to do at this point.
I ended up picking Polymaker Dark Gray ABS #474648 as it was the closest I could find. It’s slightly darker than the side panels, but has some of the same blue’ish hue. I’m using it in this model for the top hat: 3D Printable SV08 Max Top Hat / Riser coming to Printables soon!
And so far, so good for matching:
It looks great with the subtle contrast!
The camera definitely picks up the differences, but in person, they look nearly identical.
