3D Printable SV08 Max Top Hat / Riser coming to Printables soon!
Hi all,
Just a teaser, as the designs are nearing completion as are the test measurement prints and I’ll be releasing this on Printables soon. It’s a printable riser for the SV08 Max, with multiple options:
  • Windowed front panel to match the stock enclosure (tinted acrylic or glass)
  • Solid front panel option
  • 3MF setup for Polymaker Dark Gray for printing all parts on the SV08 Max
  • 3MF setup for Polymaker Dark Gray for printing corners on a Voron V0.2 if desired to speed things up
  • 3MF setup for test pieces to confirm measurement and expansion/contraction of your particular model (nobody likes wasting filament on giant prints)
  • Step files for all parts
  • Full BOM and locations to buy hardware (nuts/screws/heat inserts)
And no, this one won’t require any specific PCBWay acrylic, though I hear that’s pretty cool :wink:
Progress, color matching is fairly close, darker than the side panels but with the same blue-like gray.
Quick question, how much :laughing:?
This looks good, what hight is it. I have a BTT HDMI 7IN SCREEN and I would like to fit it on the right hand front side. Anything smaller would look crapI think.
Please let me know what you think?
Free once it’s ready.
You will need 1-2 spools of ABS, and for the window versions the tinted acrylic windows will be about $15 ($30 shipped in the US) (not from me, but from a supplier I will put in the BOM)
Doing expansion testing now on the long parts, and since I will be out of the country for a bit there will be a delay on test fitting the acrylic.
100mm, which should allow me to build in a back-right mounted Nevermore filter option. I may also release a 150mm version for those that want a heater. Only rule is keeping it under counter height for those that want it under a workbench.
How tall is the screen casing, and do you have a model of it?
I was impatient so I done it myself. Today my acrylic panels arrive.
It’s complete, looks near-factory IMO. The plexi is a perfect match for the glass. Only thing left is to design a TPU plug for the hole in the top where the filament used to come through. The Nevermore filter mounts nicely in the back corner, too. I’ll have pictures of all of that in the build-log once I post it and the STEP/3MF files.
And it’s been released: Mods for 3D Printers | nowsci.com
Isn’t it better to turn the top cover blue handle the opposite way?
Have you tried printing at z~500mm?
What is 100 mm? the total height of the riser? Why 150 mm for the heater? (https://www.youtube.com/watch?v=WvtPUMAyTUU)
Because of hot air circulation? Is there any CFD simulation of SV08 max with heater?
Hey fmstrat, did you ever end up making the 150mm version? I’m looking to install a set of iHeaters like what Gergo did on his Max, so the extra head room will be needed. :smiley:
I haven’t… but.
I just got two 200w hand heaters in from Aliexpress ($12) with the electrics to do chamber temp control. I’ve modeled the mounts to fit along the right side of the 100mm riser and to not hit the print head.
The only reason I haven’t done it yet is because 30 minutes of bed heat has worked fine for ASA for me. But I still plan to do it when I get back from traveling.
Not printing, but I have tested full range of motion at 500mm height.
Fair enough, I thought about possibility of mounting the iHeaters elsewhere, but I don’t think they will fit in another location besides the underside of the top panel. My other thought was to just stack a second setup of risers on top, but aesthetics and rigidity may be a concern. I know there’s a 150mm version out there but I’d rather not screw around with the acyrlic panels and just print it all.
Safe travels!
