Initial Impressions
Howdy. First post from a first-time Sovol owner. :slightly_smiling_face:
I just finished assembling mine last night (minus the enclosure, chamber heater and HDMI display for the moment), and I just thought I would drop some notes on my first impressions.
  • This thing is MASSIVE. I mean, I was going for big, which is why I chose a 500x500mm printer, but it’s much bigger than that. Make sure you have at least 800w x 700d space for it, and that will still be tight.
  • The instructions, while thorough, are often a bit confusing, as they leave out some details here and there, requiring you to make assumptions and figure a few things out. It happened often enough that I occasionally caught myself a step or two ahead, before I looked back at the instructions and realized it. Follow the user guide and only reference the quick start sheet to help confirm some of those aforementioned assumptions.
  • Overall this beast is extremely sturdy and well machined. I didn’t encounter any misaligned parts, untapped screw holes, etc. However, be very careful with the allen drivers provided. I snapped the smaller one off in one of the screw heads. The gap between what one would expect to be tight enough and too tight doesn’t seem that large on the smaller screws. This isn’t a knock on the included tools, as I’ve had the same thing happen with name brand tools. Maybe I just need to dial back my simpleton strength a bit.
  • During the installation I swapped out the control board fan for a quiet Noctua NF-A4x10 PWM 24V, so I’ve not experienced the fan noise that’s been drawing complaints from others. The other fan over the power control board doesn’t seem all that loud. It’s a good thing, as it uses a different 4-pin connector than that on the main control board. I didn’t feel like splicing and soldering wires, so I left it.
  • I had also pre-purchased the 32GB eMMC, so I upgraded that at one point while I had the printer on its side. This thing is heavy, and I knew I wasn’t going to want to do that, once it was fully assembled with the full enclosure and everything.
  • The first thing I printed was a benchy (natch’). Kind of comical in the middle of that huge build plate. This thing was FLYING. It finished in just over 10-minutes. While it didn’t show any problems with overhangs or general dimensional accuracy, the surface quality was lacking. The speed presets for the pre-loaded loaded print files is just way too high.
  • With the provided 200g baby spool of PLA white still loaded, I tried something larger - a zero clearance throat plate I’ve designed for my table saw. I was quite impressed by how well it turned out. The surfaces were clean and smooth, and there was no warping even on such a long, flat part.
  • I next moved on to calibrating some Overture Fiberon PET-GF15, as I’m planning to use that on a couple large projects. The manufacturer recommends printing it at 280-310C, however the SV08 Max will only go as high as 300. That looks like it going to be just enough, as it printed that layer of the temp tower perfectly. It’s a good thing, since the very next temp level (295?) failed spectacularly. I just finished the first pass of the flow rate test, and none of the tiles looked bad. On one of them I can just barely even distinguish the circle in the middle of the tile.
  • The auxiliary filament feeder it LOUD. Every 4-5 seconds the spring-loaded filament buffer snaps back to its start position with a loud, buzzing motor noise. Some have described it as sounding like a duck quack, which is somewhat accurate, assuming said duck has a 60+ year smoking habit.
  • I have to say I chuckled when I saw that in the display UI, everywhere you would normally see a button labeled “Ok”, this one says “Sure”.
A few things I’m going to address asap:
  • Install the enclosure, chamber heater and HDMI display. I wanted to establish a solid baseline before proceeding, and things are looking really good at this point.
  • Find a solution to that loud auxiliary filament feeder. It’s seriously got me considering options for just removing it from the filament feed path at this point. In its current state it’s just not acceptable.
  • Find a way to shorten the PTFE tubes and/or upgrade them to a wider ID tube. The stock tubing and run length seem to create more drag than seems appropriate. The aux feeder occasionally slips, when feeding filament all the way through. I’m considering tightening the feed tensioner. Probably should.
So far I’m pretty happy with it. I think it’s a nice printer for its size and price point. Hopefully further use will bear this out.
Heya @Geek.Verve welcome to the community!! and thank you for the nice review!
After trying resin printers, sucking in just a few to many of those fumes… :melting_face: I decided to try my hand with the 3D filament world. I found Sovol, saw that it was Open Source, and decided to try the Sovol Zero. I’ve had a great time with the printer, and am still learning daily, have been totally happy with it.
I guess that is my round about way to say the Sovol SV08 MAX or the next Sovol “large print area” machine is on my future wish list, your review helped add a few more checkboxes to my needs/wants to have list, thank you.
Cheers,
-Mike
I am also a first time Sovol owner and I had a very similar experience assembling my SV08 MAX. I also broke the tip off of the small tool but I also had an issue with the Enclosures rear cover, didn’t quite fit. I measured it, and it was about 1/8” wider at the bottom than the top. I loosened up the frame, still no luck, a file and a 1 lbs tapper and went together nicely. I ordered the wrong fan, but oddly enough this one isn’t near as loud as I expected.
Out of the box, I have had some printing issue, but I am 6 months new to printing and started with turn key machines. I am pleased with the quality of this machine just need some tuning.
So far this forum seems to have some very helpful people, I appreciate that a lot.
Nice review.
