Hi everyone,
I’m looking for some technical information about the Sovol SV08 mainboard, specifically the 24 V Exhaust Fan output controlled by MCU pin PA2 (fan3 in the stock Klipper configuration).
Does anyone know the maximum continuous current rating of this fan output, or perhaps the part number of the MOSFET/driver used for PA2?
The reason I’m asking is that I’m designing an external recirculating filtration system for my enclosed SV08. The idea is to reuse the original rear exhaust fan and add two 24 V 5015 blowers for an activated-carbon + HEPA filtration system.
The original exhaust fan in my printer is:
HXR EFC-09E24L – DC 24 V – 0.15 A
The two additional 5015 blowers are approximately:
2 × 0.08 A = 0.16 A
Therefore, in the worst case, if both systems were operated simultaneously, the PA2 fan output would see approximately:
0.15 A + 0.16 A = 0.31 A @ 24 V
I’m considering using relays to select between:
original exhaust fan only
filtration blowers only
possibly both simultaneously
Before doing that, however, I’d like to know the actual safe current capability of the PA2-controlled 24 V fan output, rather than simply assuming that 310 mA is safe.
If anyone has a schematic, high-resolution photo of the SV08 mainboard, MOSFET part number, or an official current specification for this output, that would be very helpful.
Thanks!
