Detailed Setup Information
Is there a manual/video that have detailed setup instructions. The Manual in the box appears to not be in accordance with the printer I recieved.
For example, the door noob is not assembled and not instruction in the manual.
The filament run out appear that need to be mounted to the side but all photos appears to be mounted in the back, the same for the spool holder, Also I have a dangling cable with a wire connector appearing at the right side, but nowhere in the instruction is any instruction of where to connect that cable.
Can some post a photo of the assembled Zero, specially of the Runout sensor area?
pd: The user manual that came with the machine says V1.4
Here is a pic of the Run Out Sensor from the Manual…
I relocated mine, so a pic won’t help.
You remove one of the screws from the Blue Molding & attach the Sensor to the side.
Hi @leolencioni
The manual shipped with my Sovol Zero shows V1.0 and a picture of the Sovol Zero printer on the front of it. I did order my Sovol early, they might have changed version to match what is currently shipping, but the steps should show your printer like what @Lion posted.
If it’s a issue with the shipment you can also send a message to info@sovol3d.com Customer support is available from 9:00 pm to 6:00 am EST. You can also fill out the contact forum here Help Center
With the holiday, they might have a delay.
Cheers,
-Mike
Also, read this:
Tomorrow with time, I will try to mount the Runout sensor in the blue mold. Thanks
Ok Finaly I can attach the RunOut sensor. I found a you tube video (very new) were there is a detailed shot of how the sensor is in the new models (around 8:30)
Thanks to all for the assitance!!!
