Cloned part lifting Heat soak used, brim used, other part flat on build surface
You can see where the Brim lifted at the ends, but not where the part actually lifted.
My first thought is that the front half of the plate might be dirty.
Cleaned, first IPA then washing up liquid and a lot of shower washing it
Is it brim or skirt ?
Try to use glue before printing.
Glue an a textured bed tha is so wrapped how.
It is the bottom part in the picture, top part is OK.
See the arrows pointing to the bottom part black shadow because gap between the bed and the part. Brim is ok
Sovol make junk
I use glue on a textured sheet from time to time.
