Brand new printer suddenly stopped working after few prints
The printer worked completely fine during first few prints(Speed benchy had layer shift, but it printed normally from the second try. Cable Clip file that was on a usb stick it came with also printed fine).
But the moment i uploaded my own stl via the orca slicer 2.3.0 everything started to behave strange. At first pritning started normally. But when it was close to finishing first layer, it gave me a “Move out of range” error and stopped the print.
My next move was cleaning the table and pressing colibrating button. And it is started fine at first. It moved head to the left, then moved table to the back, then returned table and head to centre and started colibrating Z axis. And seems that it’s the part when troubles appearing. As, after few moves up and down, it just stopped on palce and started producing humming noize without any movement.
Examination showed that stepper motors located right and left from the table are heating up significantly while the mottor in the back is cold and does nothing. There also new notifcation in web interface appeared. It says:
“file_manager: Inotify watch already exists for path ‘/home/sovol/printer_data/gcodes/sda1’ in root ‘gcodes’, cannot add watch to requested root ‘gcodes’. This indicates that the roots overlap.”
The forum refused to upload my files as i’m just registered there, so here is a link to google drive(With video demonstration, a gcode file i tried to print and a screenshot of error): Sovol - Google Drive
Printer runs 19.0 version of firmware
Okay, i think i’m just dumb as i found the reason of original error
I mistakenly used Sovol sv06 plus ace profile instead of Sovol sv06 ace i was needed to in Orca slicer. So the slicer just told the printer to print part outside of it’s movement range which seemingly caused an error
Welcome to the forum.
Glad you got your printer sorted.
