What would be the easiest way to park the extruder directly on top of the rubber scrappers when printing in dual mode? I am doing larger prints in dual mode and the purge buckets are not large enough for the amount of material that seeps out of the extruder when inactive.
Hello Stg58,
modifying the NOZZLE_PARK_POINT setting in the Configuration.h file & recompiling the firmware is a way, but I don’t know if this is an easy one for you.
Anyhow, I doubt that this is a solution for this kind of spillage/oozing problem. Additionally, permanent parking would ruin the scraper pads.
There should be easier solutions: Did you already try to lower the temperature of the inactive nozzle or to raise the retraction length (maybe your slicer has a separate setting for retraction before a nozzle change).
Alternatively, adding a purge tower will do the job & enhance print quality, too.
Good luck!
Björn
This topic was automatically closed 7 days after the last reply. New replies are no longer allowed.
