Sv04 extruder 2 bumping against extruder 1 at end of single mode printing
hi. I am having this:
Single Mode print - extruder 2.
At the end of the printing, when the print is finished, no more layers to go, Extruder 1 moves to the right, bumps the Extruder 2, and then Extruder 2 go to its end position and bumps against the structure.There is a huge noise too when Extruder 2 arrives at the parking position at the right side of the table. I made a video to show the issue and I am uploading it.
I wonder if this will break my printer in the long run.
Here is the final part of the gcode. If something is odd, or if there is a way to give a diffeent instruction to extruder number 2 so it will not crash against extruder number 1 thank you.
HERE IS THE VIDEO
https://www.facebook.com/fernanda.dealram/videos/3312193589057626/?notif_id=1661912525040843&notif_t=video_processed&ref=notif
I believe that Extruder 1 should move AFTER extruder Number 2 at the end. Please can you correct it, send me a good setting for the end gcode of the machine? Because this just cant be right.
1 F600 Z2.5
G0 F7200 X48.6 Y107.2 Z2.5
G1 F600 Z2
G1 F1800 E959.7438
G1 F1200 X48.21 Y107.352 E959.7612
;TIME_ELAPSED:6498.555565
G1 F1800 E957.7612
M140 S0
M107
;Single 02 end
G91 ;Relative positioning
G1 E-2 F2700 ;Retract a bit
G1 E-2 Z0.2 F2400 ;Retract and raise Z
G1 X0 Y240 F3000 ;Wipe out
G1 Z10 ;Raise Z more
G90 ;Absolute positionning
T0
G1 X-62
T1
G1 X362
G1 Y302 ;Present print
M106 S0 ;Turn-off fan
M104 S0 ;Turn-off hotend
M140 S0 ;Turn-off bed
M84 X Y E ;Disable all steppers but Z
M82 ;absolute extrusion mode
M104 S0
;End of Gcode
;SETTING_3 {“extruder_quality”: [“[general]\nversion = 4\nname = _TPU_SINGLE
;SETTING_3 printalot\ndefinition = SV04_Single_Mode_2\n\n[metadata]\ntype =
;SETTING_3 quality_changes\nsetting_version = 16\nposition = 0\nintent_catego
;SETTING_3 ry = default\nquality_type = draft\n\n[values]\nbottom_layers = 1
;SETTING_3 0\ncoasting_enable = False\nmaterial_final_print_temperature = 210
;SETTING_3 \nmaterial_print_temperature = 228\nretraction_amount = 2\nretracti
;SETTING_3 on_speed = 30\nspeed_infill = 20\nspeed_print = 40\nspeed_wall_0 =
;SETTING_3 20\ntop_layers = 0\nwall_line_count = 2\nwall_line_width_x = 0.4
;SETTING_3 \nz_seam_corner = z_seam_corner_none\nz_seam_position = front\n\n”
;SETTING_3 ], “global_quality”: “[general]\nversion = 4\nname = __TPU_SINGLE_p
;SETTING_3 rintalot\ndefinition = SV04_Single_Mode_2\n\n[metadata]\ntype = q
;SETTING_3 uality_changes\nsetting_version = 16\nquality_type = draft\n\n[va
;SETTING_3 lues]\nacceleration_enabled = False\njerk_enabled = False\nlayer_h
;SETTING_3 eight = 0.25\nlayer_height_0 = 0.25\nmaterial_bed_temperature = 60
;SETTING_3 \nretraction_combing = infill\n\n”}
Hi, i had the same problem, i just updated the firmware on the board an the touchdisplay, after that it worked fine.
My firmware was updated too. What solved was correcting the original faulty gcode provided by sovol.
Firmware is not a fix. I just got my Sv04 set up and it had v1.1.0 preloaded. Currently have this issue using the single mode 01 AND dual mode in the Sovol Cura software. Extruder 2 trying to go to wrong home position at end of print.
