Hi.
I have recently buy a SV01 Pro, and after building it, i try to calibrate it, following the official video. But when i select the Aux Leveling, it get me to the print laucher. Also when i try to save an offset for the print, if go back to the menu and just after the offset menu, it has came back.
I try to reflash the firmware (From 1.2.0 to 1.2.0) but nothing has change.
Does anyone already has this issue? Thanks for your time
Thank you so much for buying from Sovol, and I apologize for all the inconvenience.
Did you already send an email to info@sovol3d.com? If not, please send the above situation with videos and pictures and your order number, and we will check with the engineers asap.
