This past weekend, I swapped out the stock SV08 toolhead for a SV Zero toolhead.
Overall, it went smoothly, and I’m getting good prints.
But the purge blob it prints at the beginning of each print is now literally ON the left edge of the plate. If I don’t align the plate against that edge, the blob actually runs down the side of the bed. This does not appear to be a bed alignment issue in general. I set up a print with a cube centered on the plate in OrcaSlicer, and it printed centered on the actual plate, within 1mm.
So it just looks like I need to find where in the startup code to adjust the position of the blob?
Switching to CAN is actually fairly simple.
Get USB to CAN adapter board, plug into main board USB socket. Unplug toolhead cable from mainboard, attach to CAN adapter board. Then a bunch of software configs, etc.
This guide covers the major points: Zero_Toolhead_Guide
I had to do some tweaks afterward, but the whole thing was just a few hours.
Note that mainline Klipper is a prerequisite.
Yes. It’s in your original G-code. Look for the line where it moves to the left edge before clearing. This is usually X0 or a very low X value. Save the original code and it will place the blob correctly.
