🛠️ Tips for a Perfect First Layer on the Sovol SV06 Ace
After extensive testing, I found some tricks that significantly improved my first layer. I’m sharing them in case they help others too.
:soap: 1. Proper Bed Cleaning
Avoid using isopropyl alcohol. Instead:
  • Use a soft metallic sponge (non-abrasive).
  • Apply detergent and a strong degreaser.
  • Rinse thoroughly and let it dry completely before printing.
:fire: 2. Calibration with Printing Temperatures
Before calibrating, make sure to heat up:
  • Hotend: 150°C
  • Bed: 55°C
Also, clean the nozzle before calibration (I use a custom macro that I’ll share below).
:straight_ruler: 3. Manual Z-Offset Adjustment
Manually adjust the Z-Offset using either an A4 paper sheet or a thickness gauge. This is a crucial step!
:cyclone: 4. Axis Twist Correction
Run AXIS_TWIST_CALIBRATION to ensure the axes are properly aligned.
:musical_notes: 5. Better Resonance Compensation
Instead of the official method, use Klippain for more accurate results.
:control_knobs: 6. Proper Filament Flow Calibration
Incorrect flow settings can ruin adhesion and first-layer quality. Calibrate it correctly.
:light_bulb: Reminder: All calibration steps should be done with the hotend at 150°C and the bed at 55°C.
:wrench: Improved Nozzle Cleaning Macro
This macro works better than the official one to keep the nozzle clean before printing.
[gcode_macro _global_var]
variable_pause_park:{'x': 2, 'y': 225, 'z': 10, 'e': 1}
variable_z_maximum_lifting_distance: 250
variable_pause_resume_travel_speed: 150
## Nozzle Cleaning Variables
variable_cleaning: True
variable_clean_probe: False
variable_clean_end: False
variable_post_clean_home: False
variable_clean_m600: True
variable_clean_macro: 'CLEAN_NOZZLE'
variable_clean_x: 24
variable_clean_y: 230
variable_clean_z: -0.3
variable_clean_wipe_axis: 'X'
variable_clean_wipe_dist: 30
variable_clean_wipe_qty: 5
variable_clean_wipe_spd: 100
variable_clean_raise_dist: 10
variable_clean_temp: 150
variable_clean_hot: True
[gcode_macro CLEAN_NOZZLE]
gcode:
    BED_MESH_CLEAR
    {% set printcfg = printer['gcode_macro _global_var'] %} ; get printcfg variables
	{% if printer.toolhead.homed_axes != "xyz" %}
	G28
	{% endif %}
    {% set nozzle_targ = params.TARGET|default(0)|float %}
    {% set is_hot = printcfg.clean_hot %}
    {% if params.HEAT is defined %}
        {% if params.HEAT|lower == 'true' %}
            {% set is_hot = False %}
        {% elif params.HEAT|lower == 'false' %}
            {% set is_hot = True %}
        {% endif %}
    {% endif %}
    {% if is_hot == False %}
        {% if printcfg.led_status == True %}
            {printcfg.status_heat}
        {% endif %}
        M{printcfg.output} Heating extruder
        {% if nozzle_targ > 0 %}
            M109 S{nozzle_targ}
        {% elif printcfg.clean_temp > 0 %}
            M109 S{printcfg.clean_temp}
        {% endif %}
    {% endif %}
    G90                                            ; absolute positioning
    ## Move nozzle to start position
    G0 X{printcfg.clean_x} Y{printcfg.clean_y} F6000
    G0 Z{printcfg.clean_z} F1500
    ## Set lighting
        {printcfg.status_clean} ; LED feedback
    {% endif %}
    ## Wipe nozzle
    M{printcfg.output} Wiping nozzle
    {% for wipes in range(1, (printcfg.clean_wipe_qty + 1)) %}
    G0 X{printcfg.clean_x + printcfg.clean_wipe_dist} F{printcfg.clean_wipe_spd * 60}
    G0 X{printcfg.clean_x} F{printcfg.clean_wipe_spd * 60}
    {% endfor %}
    ## Raise nozzle
    G0 Z{printcfg.clean_raise_dist}
        M{printcfg.output} Cooling extruder
        M104 S0
    {% endif %}
    {% if printcfg.post_clean_home == True %}
        G28 Z
    {% endif %}
Hope these tips help you improve your first layers! If you have any questions or suggestions, feel free to comment! :rocket:
EDIT: :stop_sign: At no point am I saying that you should sand your heated bed, although if you do so, do so at your own risk. It doesn’t mean that the usual methods don’t work (using acetone, IPA or others) But what I mentioned in the post worked for ME after trying all the other options. Since I’ve done this, I’ve had zero printing issues. Same GCODE, same settings, the only difference has been the hotbed cleaning.
I got the idea to scrub the heated bed with something a little more abrasive than a sponge from a video. I know WamBam beds recommend using steel wool, but what I recommend is something less abrasive. I have used the typical kitchen sponge/scouring pad that has two parts, a soft sponge part and another part that is a little more “abrasive”.
The video I saw: https://m.youtube.com/watch?v=DzaPFlEKP10
I’m curious about the manual Z offset calibration
I’ve noticed that the bed/plate is uneven on my SV06 ACE, with the outer areas curving up slightly
It’s enough to hear the nozzle scrape the bed in those areas, even after performing the calibration in the UI
And it often leads to poor output, such that I’ve stopped printing larger items and try to stick to items that fit inside “the good zone”
I just tried the solution described in Warped Bed Question - #16 by minaskar for this exact problem and it worked like a charm! I now have a significantly lower Heightmap range in Orcaslicer, resulting in less scraping in the corners. I used the F3D file from Jig for Silicone Tube Leveling for Prusa Heatbed by motocoder and changed the length to 14 and 16 mm, use 16 the mm version if your Heightmap range is more than 0.8 mm to prevent bottoming out.
