Time to Print
If true that curiosity caused the demise of the cat, I may be next.
Can anyone explain why the time remaining to print on any particular project varies as you look at the display?
At times, long projects will show as an example 16 hours remaining. I can look at the display a little later and it will indicate 90 minutes remaining, then later 10 hours remaining.
Why?
The calculation is approximate and is based, among other things, on the gcode file.
It calculates the proportion between total code and executed code and ignores the size of each layer.
The calculation can therefore only be imprecise and only gives an indication.
That said, the closer you get to the end, the more precise it becomes.
Regards
