SV08 give up halfway through prints
So with bigger more complicated prints my SV08 just kinda gives up. It will say it’s 100% completed while the print is still partially finished. It will say that it’s taken the amount of time it should have taken in main sail but lists an accurate filament usage to what actually happened. I saw some mention that it might be worth trying to run the OS off an sd card instead of the EMMC because the later can’t handle bigger files, but I wanted to check for other information first. Cheers!
Make sure the uploaded gcode file is identical to the generated file. Comparison of file sizes should suffice.
