Tilted bed advice
Hey guys, complete beginner here. Got my brand new SV06 ACE this week, it’s been printing small objects like a charm, but trying to print the first bigger one made a bit of a mess. I checked the bed mesh and got this (see attached)
I don’t know how accurate the auto-levelling is, but it doesn’t seem to be doing any difference. (I also think the bed got scratched at the back…?)
Is it a “bad” result ? I’m not sure how I should go about this and fix it, since the built-in calibration does not do much.
Thanks for your help.
(And yes I removed the hidden foam block between the bed and the rails ahah)
Don’t take this drawing into account, mine is not better and yet my printer is working properly.
For small objects this shouldn’t matter. But for larger ones you’ll experience bad first layers.
This is a very common “issue” with most modern printers. See here how I resolved it in my case in under 30 minutes. Ideally you want to get the min-max range below 0.2 mm so that the automatic bed leveling can compensate for the rest.
