I have @björn’s firmware installed on my Sovol SV04 printer (many thanks to him). When I start the printer and it performs automatic bed leveling, the first two touch points go fine; however, the Z-axis then continues to move downward, pressing against the print bed and continuing to push, before eventually triggering an error.
Does anyone have any idea why this might be happening? Could the automatic bed leveling sensor be faulty? (I can’t think of any other explanation.)
Hello Holi, @urbnsr already mentioned the correct Z axis compensation parameter. Additionally, you may want to go trough bed leveling again: Tramming & Auto leveling + Save should help. If the problem should be still present after that, you may want to review your slicer settings.
Good luck!
Björn
