The sensor proximity how to setup?
Hello sv07(+) users,
I have a question the height of the Inductive Proximity Sensor Switch for Z Probe Auto Bed Leveling. On my Anycubic kobra 2 i had a tool 1 point lower for nozzle and the 2nd level for sensor ± 3,0 mm height. My question is how much is the difference is between nozzle and sensor? is it all so 3mm (my is mow ± 2mm) or higher or lower? I can not find any info about it. On wiki site from sovol and forum site from sovol. For me i think ±2,5mm is ok. But when home all i have z offset with paper. And check 0,10mm down it goes to 2.70 but go up it goes on by 3.10mm different of 0,40mm. Who know the best settings or how to calibrated it the best way. Gr. Marco Kersten
Thank you so much for buying from Sovol, and I apologize for all the inconvenience. You can send an email to info@sovol3d.com. Please send the above situation with videos and pictures and your order number, and we will check with the engineers asap.
I asked on facebook group and here on forum. But is a simple question… By my Anycubic kobra 2 1st release i have a plastic where i put the nozzle on it and a layer higher (2.2mm-3,3mmin height) thats a distant for nozzle and the sensor height.
printer works fine.
Is someone user know it? here on the forums?
Sovol can you please response here on the anycubic they have a tool for it but what must it be.
anycubic is round 3,25mm-3,45mm when it comes to the bed it light up blue led. and yours is a red led on when comes to the bed it goes off.
Please give me the info.
