Hello;
My print is stuck on the bed and can not be removed.
Any advices to remove the print. Thank you.
chinh Nguyen
Hello;
chinh Nguyen
Can I have a pic of that?
What filament? PLA? If so, and you’re on the glass bed, and you can out it in the freezer, do that for maybe 10-30 minutes. The print should pop right off.
This bed looks the same as that on my CR-6 SE, but the prints pretty well fall off that when it cools. I had the same problem as you with my first print, the butterfly. I had one hell of a job removing the model, and was worried about damaging the bed. At least we won’t have a problem with not sticking to the bed…
