OK. Then I’ll show you something.
Various test models of the SV06 ACE that we use for printer testing. Almost perfect. It prints overhangs, threads, and gears very well. Only an unexplained offset in the Autodesk test slightly spoils the good impression. The dummy was also created on the SV06 ACE.
Multicolor printing with more than one color in the same layer is also no problem. Switching works smoothly. No sagging of the axis in the parked position, and very precise positioning of the nozzle when resuming printing. The Orca profile has now been adapted for material changes. Clearly defined colors in the boxes. Green boxes printed on the Plus, the Prusa box on the little brother. The Sovol and the Prusa box are printed in one piece. All boxes without screws, nuts, or other metal parts. Only filament.
