No surprise, but a good printer! An SV06 ACE with a 300x300x350 mm³ print area. Unfortunately, all the errors from the SV06 ACE were also carried over. Filament change in the Orca profile is missing, Arc mode in the Klipper… Everything can be fixed quite easily and everything was already explained with the SV06 ACE. It’s a shame. That didn’t have to happen. Because the print results are impressive.
What does the bed mesh look like with the larger bed size? Reasonably flat?
Can everyone find the solutions to the problems in the SV06 ACE area or do we need an overview?
Only the “Deprecated Klipper Option” needs a small adjustment. The value changes to 0.67 because the “max_accel” is 15,000. The entry here must be “minimum_cruise_ratio: 0.67”.
The Orca profiles have already been revised by Orca and should appear with version 2.3.0.
The error messages for arc mode can be eliminated with an entry in the printer.cfg.
[gcode_arcs]
resolution: 0.25
# An arc will be split into segments. Each segment's length will
# equal the resolution in mm set above. Lower values will produce a
# finer arc, but also more work for your machine. Arcs smaller than
# the configured value will become straight lines. The default is
# 1mm.
The LED is also blocked by the display here and cannot be switched in the web interface.
All small things, but they could have been fixed.
A start has been made in the wiki. Unfortunately, there is only the faulty Orca profile from November 2024.
Until a new Orca version is released, here are these Orca profiles for users of the SV06 (Plus) ACE printers.
OrcaSlicer-Sovol_resources.zip (3,4 MB)
Had already removed this error message. Now I have carried out the firmware update and had the error message again. @Sovol This is not the fine way of restoring fixed errors. Can’t be so difficult to exchange this line if the users already specify the solution. Or?
