Hello, I’m new to the T300 printer.
In the bottom left corner, we have an RJ45 connector for the wired network.
In the configuration, we only have the wireless activation and settings.
How do I configure the T300 printer to enable and configure the wired network?
Thank you.
Have you tried simply connecting an Ethernet cable?
Yes i have connected to ethernet cable, but nothing.
And i have scan my network in a computer (ip scanner software) i don’t see anything.
Yes, after you are connected to network
Depending on how your network is setup an IP scanner on your PC might not “see” the printer.
Best method is to log in to your router’s web interface and find the “connected clients” list. The printer has no default IP and will use the one your router gives it.
If you have a cable attached, the IP should show on the printer screen.
Advanced/Show IP..
Then you enter that into Orca.
Ho, i see the problem: 3d printer is only DHCP.
I fix the problem, then IP is showed on printer.
Then i have to reserve IP in my router for the printer for connect all time to same IP else IP can change.
Thanks to all
