Loving our 2 T500’s, but have a requirement to use static IP on Ethernet. Is there a guide, or an awesome user here, that can show me where/how to do that? I keep coming up with how to do wifi, but I need Ethernet.
Thanks!
Thanks!
You can easily do this using your router.
On the router, find your printer and use its MAC address to assign it a static IP address.
Do you have access to the printer OS via SSH?
@sovol3d Does anyone know the user/password for the T500? My best GUESS is mks/makerbase.
I’m 99% sure your printer has [network-manager] installed.
You can use nmcli to configure network settings or edit the configuration.
Yes, your guess is correct.
Name: mks Password: makerbase
You guys are awesome! That did the trick. The nmcli cheat sheet was REALLY helpful. I have the T500 online and doing jobs.
Thank you!
